Hi,I have a 2012 Audi A5 s-line black edition,when I bought it it had the light on for headlight range control fault,was told it was just a reset needed or new sensor,had it on a Vagcom and came up with sensor fault on front left to which I thought fine I can sort this,located a replacement part, Jacked it up took the wheel off but can't see a sensor or any wiring that should go to it? Does anyone know if there is another version that is in the headlight and not the bottom arm...confused with this on 🙄🤔
A customer had this happen and I reset it and worked fine
Thanks, I had a Vagcom on it and it did turn the warning off but drove maybe 100 meters and it came straight back on again?🤔
Have to reset the range not the clear the errors
Discussion Starter #5
Ah right ok may give that ago then,still not sure why they isn't a control sensor on front suspension arm though
