Hi guys,
Mrs A5 has been getting the "Headlight Range Control Defective" message for some time now so I thought I should investigate. From VCDS it was showing the G78 sensor showing faulty with zero voltage going to it! So Ive changed the sensor, and still showing as faulty. Mind boggling because the headlights do actually function as intended - it just keeps throwing the error on the dash for some reason!?
Anyone had this problem before and if so what was your remedy
Thanks,
Jack
Thanks,
Jack
