2008-2016 Audi A5 Headlight Housing Removal
Once it's out remove the rear panel by releasing the wire clip and then twist the bulb locking mechanism to release the bulb- don't touch the bulb when you replace it.
Saw that video my headlights are different thay have a round rubber covering at the rear not the same clip I just can't wiggle the unit out also most appears cross member needs removing.2008-2016 Audi A5 Headlight Housing Removal
