81 - 100 of 104 Posts
· Premium Member
Hanif mate she looks totally STUNNING!!!! Well done mmmmmm.
Discussion Starter · #89 ·
  • Here you can see the wires for the front PDC that I retrofitted. I bought the kufatec harness but they use a 12 pin plug which I replaced to a oem 6 pin plug as it only utilised 6 wires. I also
    176403
    176404
    cut and repinned various parts of the harness like the bit going to the switch and also the buzzer as those were too long and I didn't want any excess wires in my car only a little slack to not have tension on those wires and pins.
    176402
    176399
    176400
Discussion Starter · #91 ·
I ordered a new Crash bar/Cross bar through Red Mist Racing to fit a bigger 4 Pass Heat Exchanger by Merc Racing. These images are just from current state of vehicle while I await the new parts.
Discussion Starter · #92 ·
MERC Racing 4 Pass Dual Core HX installed. Additionally, instead of running the air filter behind the HX it will go in front for cooler air. I also got Red Mist Cross bar that essentially frees up space to run bigger HX and also provides more air flow to HX and radiator.
Discussion Starter · #93 ·
Did some modifications for easy oil changes for blower without removing anything but the fill cap
Also mode some cosmetic changes to the engine bay to clean it up a lot from all the hoses. They are now ran behind the firewall with a very clean install.
Sent from my LM-G820 using Tapatalk
