Daft question guys, I want to remove the centre console trim so I can carbon it but it means I would need to unplug the handbrake switch, if I disconnect this is the car likely to roll off into the sunset.
Don’t you have a park mode on the automatic? And if manual then I’m not 100%.Daft question guys, I want to remove the centre console trim so I can carbon it but it means I would need to unplug the handbrake switch, if I disconnect this is the car likely to roll off into the sunset.
My car is a manualDon’t you have a park mode on the automatic? And if manual then I’m not 100%.
~Alex
Thanks for the reply bud, looks good, I've done the rest of them but I've tried doing it 4 times without taking that one piece out but no bueno.Just did the same thing.
I just put the car in 2nd and as it was at the side of the road turned the wheels enough to stop it rolling.
Either that or just chock the wheels.
Getting the centre console plastics out are a right pain btw.
Quite pleased with the results though. View attachment 180236 View attachment 180237 View attachment 180238
