21 - 40 of 60 Posts
Hello,
My sw version is:
MHI2_ER_AUG22_P3241
MU Software: 0678
Any chance of a firmware update to enable satellite image?
I spent a few hours today looking through various forums and threads but I am not able to understand exactly if my car can be updated..
Many thanks in advance!
Hi @congo ,
I have the latest version of the MIB2 FW with Nvidia Chipset. I have read that you say that although Audi has not published anything, something can still be done to have the satellite view.
What can be done? Can you tell me, please, where to get information?
thanks
Audi A5 MY2017, qualcom chip. Two dealerships said it can not be done. Its done by congos manual, about 20 minutes.
Thank you congo!
Which one of the TPI files did you use they all have different numbers and I don’t know what it relates to?
Discussion Starter · #25 ·
Based on the info you provided for you is MHI2Q_ER_AUG22_P5092.
Keep in mind that SatMap will only work with active connect subscription so you have to renew every year.
Downgrade to current version might not be possible.
Regards.
Hello
I like that with the cards very much. The connection of the cards in the MMI is still limited. since only 2G works after the 3G subscription, this will probably not work with the map download either. A maximum of 10kb / s is transmitted via 2G. that will hardly be enough for the cards
Hello
This is simply wrong, the 3GP uses 3G and the MIB2/MHI2 uses 4G!
Discussion Starter · #29 ·
2G will be ok for MMI3G+ systems.
It does take a bit more time to do the initial load but then unless you are driving with 300km/h and map is zoomed in to 30m ... it will work just fine.
Regards.
i am a german. I must translate every treat. That is not realy fine. I wanna have the Google Earth on my MMI3G+ in my Audi a5 8T facelift 2012.
I have the MIB2 high qualcomm unit in my 2017 A4, i have never had the google earth / maxar option available it just says standard, traffic or satellite maps which doesnt work it. When i try and choose satellite it says could not communicate with myAudi servers. My current software version is MHI2Q_ER_AUG22_P5095 and MU software is 1329
Am i supposed to use that download link with my version number on it and update it like that?
Edit: My unit is a retrofit
Discussion Starter · #35 ·
Hello,
because your unit is retrofit if the old one didnt had connect package then Sat Map will never work thru Audi.
There is option to downgrade to 3638 and then use Google (check the other thread about details).
This is only if you want to use Google/SatMaps.
Regards.
Hello,
Regards.
Thanks for that, if i pay for one month of the audi subscription then perform the downgrade will that work? I have issues on my unit with audi connect as its a retrofit it always fails to connect to myaudi servers
Discussion Starter · #37 ·
As its retrofit ... i dont think so.
Only option could alternative online services.
Hi Congo!
First of all thank you for the work and time you're spending to fight for the small customer!
As I read in your topic, there is a solution for older models. I have a A4 B9 Build in 2016 with no "Q" in drivercode.
Could you please help me getting google earth view back?
I've got an active audi connect service.
Thank you again!
Hello Congo, firstly, thank you very much for your work. I have only one simple question. Just like other I lost access to satellite maps in my A4 B9 Allroad. I read through your post and I believe I can do the MMI update myself to make it work. My MMI version is MHI2Q_ER_AUG22_P4170, software MU 1117. I also read the technical service bulletin but I´m a bit confused now as in the chart there is only "software train" P4170 and "software version" 1118 stated as capable of update. I´m not sure now if I can safely download the new firmware and update it via SD card. Many thanks!
21 - 40 of 60 Posts
