141 - 156 of 156 Posts
Read Only
Congo are you able to help me with the online traffic license activation? the car did not have this as standard and I can not buy access in myaudi
Discussion Starter · #143 ·
Such questions should be asked in the relevant topics or if such does not exists in PM.
For Online traffic on MMI3G+ i cant help you.
Hi Congo, can we contact you regarding Google Earth solution for RNS850? I have a new registration and I can't send a message. Thank you.
Hello all,
some of you might already noticed as of Dec 2020 Google Earth was disabled for all vehicles older than MY2018.
That left all legacy MMI systems w/o that option.
I'm happy to announce that there is a software solution now that can make GEMMI work again :)
Installations are performed remotely, all you need is empty SD card and active green menu as i will need some details from it.
More info here :
Code:
https://www.audi-mib.bg/audi-google-earth/
For MMI3G+ systems min software version required K900, best with K942/P1001
For RNS850 systems min software version required K821 (it might work with older but it was never tested)
For MIB1/2 systems almost all software versions are covered, if update i needed i will guide you thru the process if you are not comfortable doing it by yourself.
Active Connect subscription is not required, but if the system was retrofit i need to know that prior to making the activation pack.
Data connection is required.
MMI 3G+/RNS850 systems -> Price is 75€ one time only.
MIB1/2 systems -> Price is 180€ 150€ one time only.
Because of recent questions from members i will state that here so it's public - No information about location of the car is transmitted back to me when using the software.
As some of you may have concerns about reliability of the service I'm extending the warranty period to 6 months.
What is covered?
If you have MIB1/MIB2 system and the software is not able to function as intended before the end of the 6th month since it was activated and I'm not able to restore it in 2 month time then you will get up to 50% refund.
What is not covered?
Unfortunately due to its age MMI3G+ systems are not covered by any warranty period.
End user action that somehow prevented the software from functioning correctly.
Isolated case where only one system is affected (i believe it's clear that is local problem)
Activation that is not made direct from me elsewhere using my files.
Warranty VOID
As expected some will try to reverse the code and/or try other techniques to understand how it works. That is fine for own education but if shared publicly will result in immediate support termination w/o any refund. No new updates will be offered.
Software is expected to function properly for more than 2 years. Any speculations that it will stop in a week or two are nonsense's by people that have absolutely no idea how this thing actually works.
Please write in English only. Foreign users can use google translate to do that.
Required information for MIB systems:
I will provide software package that will do the information extract for you.
Required information for MMI3G+/RNS850 systems:
1. photo of GreenMenu -> Environment screen.
2. VIN or FAZIT. FAZIT can be seen from VCDS -> 5F, Advanced Identification.
3. Version of the software should be at least 900 or newer.
If you dont have green menu activation I will provide script that will do the information extract for you.
Demo of A6 4F (retrofitted MMI3G+)
Demo of S4 B9 (W/o fix from Audi)
Contact for more info.
The price paid is not for providing the satellite images, they are freely available. It's for the time taken to make it work again.
Hi congo, can you reach out to me please for the google earth, everything is done by obdeleven. Wifi module and esim is active. Google earth loads to the max but doesn't boot. Picture is on the mmi, but the maps never show up. My audi connect is expired i don't want to subscribe again. I have an audi Q5 2018 with Qualcomm. Mhiq2-us-aug22-p3639 mu0918. Thanks.
Discussion Starter · #154 ·
If your version is 1117 then you dont need to update, this version is supported for Google Earth.
Send details on PM.
Hi @congo, I have a question if the access to the servers is limited in time or depending on the amount of data. After starting the MMI, it works correctly 15-30 minutes after this time it does not load new images for google earth. Internet access is available all the time (audi conect services are connected to the internet). My MMI 3G + with modified internet access.
Best Regards
