Has anyone experienced their Fan Speed on their AC's changing? If I change my Fan Speed from 3 to 4 and see it on the screen at 4 before it goes off, five minutes later when I notice it blowing more than what Fan Speed 4 should be, I hit the Fan Speed button to check, only to see that the Fan Speed is now on 5. When changing the speed slower it will aslo move one speed slower a few minutes later... I have actually kept the screen up and watched the Fan Speed change on its own. Is this a normal characteristic or operation for our AC systems??? Thanks!!
If the climate control is set to 'auto' it should adjust the temperature and fan speed itself (std Audi function). Although normally when you manually adjust, it turns the auto off. I've been in audis for 10 years and they have all worked this way. I haven't got my A5 yet, so maybe they have made some changes...?
oh no the infamous german electrical gremlins =(
very notorious in bmw's and mb's...
i had a problem with my bmw where the fan was on, but nothing came out of the vents...
problem just fixed itself..very odd.
good luck, and just like what ian said, if you select ur own fan speed the auto should be over riden..hmmm
