2015 A5 quattro sport back s-line 2ltr tfsi 224
I know it shouldn't be this hard but be kind, worked last night and only had 2hrs sleep today.
Trying to see if I have towing prep installed, cant find the sockets needed for controle module.
The web site says check you have the fuses for TP
Looked at manual and it says fuses in right side luggage compartment.
Fuse carrier B (black) fuse numbers 2,3 & 4
My fuse box looks different to owners manual and have 2 black carriers ?see pics
177897
177898
You don't need A from the manual, that is all cabriolet. The 3 fuses from the manual are positioned 'vertical' , the fuses in BCD are all ' horizontal'.
It looks like B from the manual = A in your car. Does that make sense?
C would be C, and D = D.
In A (car, B in manual) 2,3,4 are missing.
Edit: I checked my fusebox and manual. In your car B has moved to A. You have an electric bootlid? The other ones are alike.
In my manual the Amps are printed behind the fuses, that makes it even easier to recognise.
No electric boot lid A5 B8.5 2015 don't have them. Fuse 1 might be dash cam will check tomorrow.
