1 - 11 of 11 Posts
2015 Audi A5 S-Line Quattro White
Hi guys
I have recently lowered on Coilovers and replaced all arms ball joints bearings the lot both sides front
I’ve noticed now when I full lock right my near side front wheel kinda skips out as if the control arm has given way but everything is tight and in order
Does anyone else have this with lowered A5’s
Is it quattro?
Juddering on full lock is normal on quattro apparently. I have never seen an explanation as to why. Your manual should warn you not to hold full lock for an extended period - probably these two things are related.
This is quite common and certain tyres seem to do it more than others. Have you had a full geometry alignment done?
It can be stopped by alignment, but it is normal. Usually when you have it aligned out, it affects the steering and possibly shoulder wear on the tyres. It's kind a of a balance between alignment and accepting a bit of hop/scrub on full lock. I think more negative camber can also stop it, or mask it as the wheel will be leaning in and sliding on the inside of the tyre, rather than the outside, which gives the scrub/hop/
Discussion Starter · #6 ·
thanks guys for the information
i will maybe go for alignment to atleast try and reduce it ,although i have put Pirelli p zero tyres on and have notice it more
I'm guessing you have already had a full alignment after you replaced the suspension? :)
Discussion Starter · #9 ·
im having the front coilovers replaced so once thats done i will get it re aligned else where
if you are using coilovers, just so you are aware, on the these Audi's there is little camber adjustment that can be done depending how low you go without some other modifications.
Discussion Starter · #11 ·
I’m unaware of how to adjust the camber on this a5
1 - 11 of 11 Posts
