OK, well since I'm a nice guy, I decided to go get my US spec headlights out of the garage and check them out. (Like I said above, if you still have yours lying around, I would think you could have easily done the same.)
Bulb removal procedure:
1. Remove the round rubber cap from the back of the headlight housing. Once the cap is removed, the bulb location will be staring you in the face. (photo 1)
2. Twist the bulb housing counter-clockwise to unlock it, and then pull it out.
3. To remove the bulb from its housing (as seen in photo 2), press inward on the bulb and twist it counter-clockwise (with the bulb facing you) and then it will release from the bulb housing. (
Note: Don't touch the bulb with your fingers since body oils decrease the life of halogen bulbs.)
The bulb type is
H21W. It's a 12-volt, 21-watt halogen bulb with a BAY9s base. (photo 3)
As for where to find those chrome type of bulbs that blink amber,
this place sells them.
