I have vcds done all the coding tweaks now moving to the retro fit type of stuffConsider getting Obdeleven or Carista.. The possibilities of tinkering are endless..
Needle sweep.
Dipping mirror.
VIM
Etc.
I would say without the hardware installed it’s pointless for the Audi drive as it would have no way to physically change anythingYou could have a look at audi drive select with VCDS - there is a thread on here somewhere, although I'm not sure there is much value if you don't have the hardware installed. As Alex says, interior lighting seems popular. If you have the right lighting module you can integrate new lights that work like factory.
There isn’t much “easy” retrofits. But there’s plenty on this forum if you search for it.I have vcds done all the coding tweaks now moving to the retro fit type of stuff
Well, the steering might respond. And you can buy an ADS switch. It would need a closer look for your car.I would say without the hardware installed it’s pointless for the Audi drive as it would have no way to physically change anything
