Hello,
I was just looking for a bit of help as I am not the greatest car guru.
I have recently purchased an Audi a5 2009 2.0 TFSI 180 and my parents are starting to think it was a bad purchase at my young unexperienced age of 19 so I was hoping someone could lend a brain??
61500 Miles - Good tyres with good tread - Oil just changed
Purchased 1 week ago. Had been sitting prior to me picking it up for about a month. The previous owner had driven it constantly for 15 months before it was sat. It was sat as he used a different car.
  • When changing gears at low speeds car judders and makes a very loud metal clunking noise.
  • When putting my foot down on the accelerator and taking it off it also makes a loud metal clunking noise.
  • When these both happen it feels like you're running something over.
  • If you change gear very gently and at the exact correct revs it won't make the noise.
  • Left front wheel(well I think its the left front wheel) makes small warping noise, not very loud but noticeable with music on.
  • When I put my foot down on the accelerator quite hard the wheels get sort of stuck before then going again, feels like a bit of wheel spin but makes loud clunk noise, this happens if you put your foot down at any speed.
  • My oil seems to be going down quicker than expected but I haven't been able to monitor it that much as only had the car for 5 days.
If you drive the car gently there are a lot fewer issues and you would even be lead to believe there weren't any issues.
Any help will mean the world to me!!
Thank you in advance.
Charlie mate.Listen.
Anyone who knows little about cars should always get professional help cos its the biggest purchase we make apart from a house. So for the house you have a pro make a search and a survey before you buy, the AA and RAC will do the same for a car. The main question for you is did you purchase the A5 privately or from a car dealer??
I sincerely hope that you purchased from a dealer cos if you did TAKE THE CAR BACK TODAY AND DEMAND YOUR MONEY BACK COS THE CAR IS NOT FIT FOR PURPOSE.
If instead you bought it privately I would go to a good solicitor and get some advice.
The problems that you mention sound to me VERY severe indeed. The 2.0 FSI cars of that era had a major manufacturing fault whereby the engines consumed oil unless reworked by the VAG dealers and many/most were eventually done under factory warranty. If your car has not been done then it could cost you thousands for a new engine. Read on here, there are hundreds of cars affected. It also sounds like you have a gearbox and drivetrain problem which could be connected.
Good luck!! Simon
I hope that you purchased from a dealer cos if you did TAKE THE CAR BACK TODAY AND DEMAND YOUR MONEY BACK COS THE CAR IS NOT FIT FOR PURPOSE.
Good luck!!
Hi Simon,
Thank you very much for the reply, that was very quick.
Unfortunately, I did purchase the car privately, I had seen a forum about the oil issue and my mind was adventuring to that point.
I have not known anyone to have used RAC or AA to check a car before purchase so I didn't even realise it was a thing but from now on I will be certainly doing so.
I have seen people on the thread who have had there Audis engines rebuilt by audi if they meet certain criteria which I think I may but that was a US criteria so unsure about UK.
Obviously, if I was to go legal do I have any chance and would it be costing me a fortune, the guy is saying there was no issues he had noticed when he had it so have come to realise EXPERIENCE IS KEY and I have been scammed.
I appreciate the help, I really do.
Welcome to the 2009 Audi A5 club :) Also recently purchased same car myself.
IMO you should only buy 2008 to 2011 TFSI if the seller can provide invoice from Audi the piston rings issue been fixed. I have learned over the years never believe a word that comes out the sellers mouth.
I was reading another member purchased similar car and Audi may repair the engine if owner is willing to pay 10% of the repair cost. You could approach Audi and try your luck. I recall the 10% was estimated £600/£700
My personal opinion is you should not purchase a 10+ year old performance car unless you confident enough to diagnose and carry out most of the repairs DIY.
A car this old will have so many age related maintenance due now and if you take to garage will empty your pockets.
My 2009 A5 has leaking front shocks and 4 upper control arms cracked. I would think most 2009 A5 suspension is past their prime and needs refresh.
The noise could be a wheel bearing - there's no play in them even when gone and are about £250 to replace.
It could be a drive shaft CV joint, in which case your looking at about £500 each side.
I say this from personal experience - my nearside bearing went at 60ishK, my CV joint at 100k (along with the main propshaft Central bearing)
