How many miles on the car and on these tires? That inner edge wear is not too bad. My tire wear on same tires is similar. I got 20000 miles from last set of Super Sports. These PS4s are at 15000 and look like they will go 25000. I check camber with a digital gauge and it is -1degree front and - 1.5 degree rear. A bit of negative camber is desirable for cornering performance and to even tire wear when cornering harder. More camber, lots more, is desirable if tracking the car. I’ve seen guys wear the front tires outer edge to the cord in one day at track events. Thus, alignment is somewhat of a compromise. Proper camber depends on how the car is typically driven. You might have it checked and especially for toe setting. Toe is obvious when it gets off though because the steering wheel position when driving straight will usually be off center.
as suggested above, rotate them front to rear.
