1 - 2 of 2 Posts
Car going into limp mode with this fault.Is it possible to map out sensors in exhaust.It's being run with no dpf/cat or silencers.Cleared dtc but soon returns also P0401 crops up intermittant with it
Discussion Starter · #2 ·
Bump....changed lambda as its easy but still happening.Car can be fine for a while then just as i go to overtake dam thing goes into limp mode ..embarrasing.Any ideas folks.Is there common boost pipes that are prone to leaks etc.Injectors have been checked recently too
1 - 2 of 2 Posts
