1 - 2 of 2 Posts
2 Faults Found:
4807 - EGR System
P0401 00 [100] - Insufficient Flow
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 75493 km
Date: 2016.09.05
Time: 21:03:27
"I've fitted a new EGR valve and solenoid still got the code!"
5308 - Throttle Body Actuator Bank 1 (J338)
P0638 00 [032] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Mileage: 75515 km
Date: 2016.09.06
Time: 05:47:05
"I've fitted a new throttle valve still have the code!"
Did you find any solution for the P0638 curious as i have the same problem atm, ive changed to a brand new throttle body and no change same code still reappears!
1 - 2 of 2 Posts
