I'm getting the following fault code on my 2016 S5 with a Carista scan:
Heater & air conditioning
Part #: 8K2820043AQ
Component: KLIMA 3 ZONEN
Coding: 663F028080 (hex)
Fault codes:
01207 Control Module for Auxiliary Heater (J364)
I cannot get it to clear/reset. The 8K2820043AQ part # is the climate control panel in the centre console. I done a lot of Googling but I haven't found a solution. As far as I can tell my car doesn't even have an Auxiliary Heater fitted.
Any suggestions please?
Sponsor
...did you try to turn on the aux heating with carista? If you don't have it, the error makes sense.
Discussion Starter #4
@IngolWorks - Eamonn
You, Sir, are a genius! (y)
It was enabled in the Carista menu. Not sure how that happened. Anyhow, now disabled and fault code cleared.
Many thanks. ???
