1 - 1 of 1 Posts
Hi all,
Hoping someone may be able to help me regarding coding in facelift LED tail lights to my facelift A5 coupe.
My car - 2012 SE (Facelift) Coupe which came fitted with Standard Halogen Tail lights.
I have used the following Adaptor to connect the new facelift lights and fitted it all in.
Red wire and yellow wire on the adaptors were fished through the hatch and connected to the opposite connector (inner light to outer light and outer light to inner light).
I have attached a image of the coding i used that was sent with the adaptors. All coding has been done as given in the "new" column in central convenience (46) module on all the given channels.
176687
The issue i have is the following with new tail lights -
Side light/drl pipe light not working
Fog lights not working
Inner indicator are very very dim
However, outer indicators, brake lights and reverse lights work fine.
Can anyone advise what i can look at to resolve these issues and get the lights working correctly please?
If any more info is required please let me know.
Thank you!
Harj
1 - 1 of 1 Posts
