1 - 7 of 7 Posts
I have a rental car right now and one night thing about it is the low beam lights on the outside come on when you unlock the car and turn off when you lock the car. This a nice feature to be able to see around the car in the dark with out the car being on. Is it possible to program with VAG-COM something simular to this?
it would be hot if you could unlock the car, and have the LED's turn on from a distance using the key like the car just woke up ;-)
What the OP is describing isn't "coming home", but "leaving home." That's a feature in the MMI which is off by default on US cars. But it's what you need to enable in order to turn on your exterior lights when you unlock the car.
Also remember that the headlight switch needs to be in the "Auto" position for this to work. That's also true for "coming home" lights when you turn the car off. Because it's tied into the automatic light circuit, neither lighting option works when it's bright ouside...the car only does "coming home" and "leaving home" lighting when it's dark.
1 - 7 of 7 Posts
