Hi all,
Help please.
Quick background, had this exact issue about 8 or so weeks ago, got it to a garage, fault wasn't present when they started the car, ran various tests on the battery and alternator and couldn’t find a fault. Cars been fine ever since. Indeed when I had got it back, it’s been fine.
ffwd to now, and the issue is back. I have a glaring warning appear after about 3-5mins of starting the car in the screen between the speedos “ alternator fault: battery is not charging”. Ignore it and start the car a few times and you’ll find the battery dead.
Charge the battery with a trickle charger, registers full, I leave it overnight and re attach the charger next day, confirms still full. Start the car, fault returns and can’t clear the codes (DTC power management codes throughout - so limited fan function, can’t heat rear screen or use seat heaters etc).
Most garages can’t seem to fit me in until next week, and it doesn’t give much confidence thinking you can pop to the supermarket only to find your car dead on return.
As the alternator was tested before and couldn’t find an issue.. I’d be surprised if it was at fault.. but regardless is there any way I can test things to isolate if this is a battery or alternator issue? Instinctively I’d like to just replace the battery but at £150-200 a pop, don’t want to do this to find it’s wasted money (side note, my current battery is an AGM 12V 105ah 950A varta, should I match this like for like? My car doesn’t have stop start (at least enabled), searches suggest thats what this battery is good for, and registration searches give you wildly variable batteries based on registration - how do I know which would best do the job?).
Between my trickle charger and code reader thing I can already say the following;
-On testing this morning from leaving the battery full last night, the charger registered 12.9v on connection before charging started again.
-With the car running, my code scanner registers via ODB port between 11.36 to 11.19v while running.
-on charge it registers c13.4v / 10.1A
..what else do I need to test to help identify what could be at fault?
Help please.
