I have an Audi A5 Sline Sportback Facelift 2012 Auto
I can engaged the parking brake using the electronic handbrake manually switch been pull upward and I can release the brake when I pressed the acceleration pedal.
The brake will NOT release if I press the electronic handbrake switch downward.
This has never been a problem for me as I don't manually release the handbrake using the electronic handbrake switch, only using the acceleration pedal.
Lately, I have had some complaint from MOT centre saying I should be able to release the handbrake manually using the electronic handbrake switch.
No error showing in VCDS relating handbrake
My question is,
Is this normal?
Should I been able to release the handbrake using the electronic handbrake switch?
Do I have a faulty switch?
Is there a setting within VCDS that I need to enable?
Thanks for your help
· Administrator
In order to release the electronic handbrake, by pressing down the handbrake switch, you must have yr foot on the brake pedal.
In my pré-facelift A5, I did change that, so I could release the handbrake all the time.
but this can be dangerous, if the switch is pressed accidentally.
  1. Select module 53 - Parking brake
  2. Select Security Access - 16 and enter the code from the popup screen (25194 - pré-facelift / 78713 - facelift)
  3. [Adaptation - 10] --> channel 04 – Click on ‘Read’,
  4. Change the value into “0” ( = inactive)
I tried all that and it don't work
Also, my 53 - Parking brake module channel has many options but I do have "Manual release"
I set Manual release with button and brake pedal depressed and it's not working
See attached image
