Does anyone know how to remove the electric seat adjustment cover panel on the side of the seat? as shown in the picture attached
wanting to remove them to get them done in carbon :)
I tried removing this earlier this year unsuccessfully.. The fastener at the rear is a plastic rivet with a push pin center. That only loosened up the whole plastic vanity panel but it seemed to clip onto (at the front of the seat) what looks like 15 in your photo and I could not get any angle nor light up in there to see how it was fastened or clipped on there.
That being said, I only needed access to the seat adjustor and I got enough access with just the rear push pin rivet off.
Regards
Take the seat out, then you'll have easy access to loosen the metal frame it's hooked on to...
Once it's loose you can easily remove the panel after unscrewing the 2/3 controlers that are on the back of it (remove the switches first though).
