First and foremost, I am an E-code dummy:confused::confused:. Secondly, I'm sure that I am not the only one who is inexperienced :)confused:)in this area and would like to become more educated. So What im looking for is:
-What do you need to perform code changes
-Any important tips/ precautions
-A list of codes we know of and what their effect is
Thanks,
Charles
Hi Charles,
You're not alone. We've all learned things from each other on this forum. I know I've certainly learned a whole lot of things that I never knew about prior to joining this forum.
Just to clarify... when you see reference to the term "E-codes", it's typically referring to European spec headlights (i.e., with the clear side markers instead of amber like in the US). I'm guessing the term may be derived from the fact that European regulations (or "code") mandate a clear side marker. And then the 'E' is short for European. I just prefer to use the term Euro spec headlights, as that's more clear to everyone.
But, it sounds like you're really wanting to know about all the VAG-COM mods. The below links should provide answers to all of your above-referenced questions:
http://www.a5oc.com/forums/showthread.php/vagcom-vag-com-2496/index.html?t=2496
http://www.a5oc.com/forums/showthread.php/have-solved-drl-2468/index.html?t=2468
http://www.a5oc.com/forums/showthread.php/some-new-lighting-3490/index.html
Yup, that is what i meant, i did a search for "codes" but got nothing, so thanks for the help.
