1 - 7 of 7 Posts
· Premium Member
I'm thinking about going to the next local dyno day with a car site i'm a member of.
Instead of putting the supra on the Dyno (which has big issues with the type of dyno it goes on), i'm gonna dyno the A5 just for the fun of it!
Can anyone see any issues with Dyno'ing the A5? Any issues regarding the drivetrain, cooling or anything? or should everything be fine?
Make sure it is a 4 wheel load dyno. Otherwise you will put a ton of strain on the center differential. Fill up with fuel from the station you would normally use for most accurate results for your conditions.
1 - 7 of 7 Posts
