Rab, sorry but your results look very suspect to me; how can power at wheels be so close to engine power? (it seems there is very little transmission loss) and maximum power rpm seems too low, and how can maximum power arrive at different RPM (engine power and wheel power is just a way of estimating power loss via the transmission as you cannot measure engine power -accurately- without taking the engine out). Did they give you a copy of any graphs?
I agree, thats why it's good to compare results. I have got a graph, i'll scan it when I go in to work on wednesday (I havn't got a scanner at home).
I did say that i wouldn't make judgement on how they acquired the engine output figure. They may have used a standard conversion value. And it doesn't make sense that it's at a different RPM, albeit 20RPM!
The max power RPM should be 4000-4400RPM if you go with the handbook. However, the max torque RPM is fine.
I do think Dastek used the wrong gear, though.
