Hi all,
Finally got the passenger and drivers door glass and will be replacing it myself as I’ve run out of diy house jobs thanks to the dreaded virus.
im sure this has been asked before...anyone know of a video or instruction on how to diy the Windows? It’s an a5 coupe on a 2010.
appreciate it and hope everyone still staying sane.
steve
Hi you have probably done this by now but best place to look is YouTube at window regulator replacement's i used the video of an audi tt as a guide as it is almost the same as an a5 same procedure as long as you have removed door card.Its actually quite easy with a frameless window.
Cheers....did that and was easier than I thought. Always better to check...saves problems once you start.
cheers
