1 - 2 of 2 Posts
My Car is a MY2010 Coupe
It looks like my driver's window (LHD) won't lock upside after i close the door every time.
Very often i have to manually operate the button to make it reach the top.
Any Ideas?
Have you tried resetting the limit switches on the window?
Do this by rolling the window all the way down and then holding the switch down at end of travel for 10+ seconds, then do the same in the up direction. Then try it and see if the window behaves correctly. If not, it could be a problem with the limit switch itself?
1 - 2 of 2 Posts
