1 - 8 of 8 Posts
Hi, I've been getting a the coil light flashing on a few occasions now and vcds has gave me a fault regarding the dpf pressure sensor implausible signal.
I have ordered a new genuine Audi pressure sensor and was wondering if I need to adapt it via vcds.
If so could someone give me instructions on how to do so.
A5 3.0tdi 2011.
Thanks.
Discussion Starter #2
Fitted new sensor, filled up with shell v power and now I have the particulate filter warning light up on the dash.
Can anyone tell me if the sensor needs to be adapted at all.
Thanks.
John sorry no idea mate. Some experts will surely be along soon to help. Personally I am a big fan or Redex and or STP and I add a bit to the fuel every month or so cos I think that this helps to keep the injectors clean, and I guess that these new fuels like V Power do a similar thing. My old Merc Vito V6 van has 160k kms and still flies!!!
Discussion Starter #4
Thanks Simon, been on a long journey today and the dpf light went after I restarted car after 60 mile drive.
The car seems to shudder and shake at idle though and idle is still 100rpm or so higher than it usually is. Usually sits at just over 600rpm. Car feels like its lacking power too.
Discussion Starter #5
I've been logging the dpf readings since Feb 15th. Do these look healthy.
Thanks.
Discussion Starter #7
Still same problem. Replaced dpf pressure sensor. Been on a 140 mile drive on dual carriageway this weekend and car seems to be stuck in regen mode.. higher idle, louder exhaust.
Checked dpf values and seems like it hasnt regen in 1000 miles but ash a d soot level low... so dont understand why it would be constantly trying to regen.
Might be worth checking egt levels, if it is in regen mode which it sounds like, should see high temps
1 - 8 of 8 Posts
