1 - 6 of 6 Posts
just a quick one guys, is there anyway for the DRL's to come on when you unlock your car from a distance in daytime. On auto mode at night time they come on when you unlock the car and stay on for approx 15sec when you lock, i wish that would apply for the day aswell. Possible ???
I don't know if it's possible, perhaps someone else has the answer!!
Mine are set for 30 secs.
On control panel press: CAR-Exterior lighting-coming home time-then adjust (I think!) :lightout:
iv done it. you just have to mess around with the exterior lighting settings and adjust the going away lights (or coming home lights wtvr it is)
That should adjust the time... but as far as I know, the LEDs only illuminate when the light sensor is triggered?
You can adjust the sensor trigger with the "early" and "late" setting. But I don't know if this setting is just used for the headlights or for the comming/leaving home feature as well.
The setting early and late is for the regular lights (Xenon). The time for comming home / leaving is indeed just for the sensor (so, will only work when it's gets dark).
I think we should change a setting with the VAG-COM or other cable. anyone?
1 - 6 of 6 Posts
