1 - 7 of 7 Posts
Hi, what is recommended for mixing with coolant, tap, distilled or deionized.
My manual says only to mix with tap water but our water is very hard.
Cheers.
· Premium Member
Good plan Nigel, best idea for sure.
Audi S5 sportback
Premix is convenient, but if you want a higher water content for better heat transfer (from what I've read) use distilled.
Never use tap water, Has minerals in it that react with the aluminium and create 'deposits' in the cooling system. Not ideal
Yeah I already brought coolant concentrate and a few bottles of deionized water, but reading through the manual it states use only tap water... but I opted for the deionized.
Read a lot of posts about deionized water reacting with the metals in the coolant system....
I'll use pre mix next time, Got to be easier.
180730
1 - 7 of 7 Posts
