1 - 2 of 2 Posts
I have a pretty weird situation. In my A5 B8, I have MMI 3G HIGH with a Coming/Leaving Home lights option.
I can set the timing for both but it's not working.
I don't have automatic lights as well, and I was reading on some other forums that you need to have it (to have this option working - is this true?).
How it's possible that I have that option in my MMI 3G HIGH and it's not working(without automatic lights)?
Do I really need to have Automatic Lights or there is an option to activate it with VAG VSDC?
Please help if you have solved this issue!! Thanks!!
You need automatic lights for this to work. The fact that you have the option to adjust in MMI is a bit of a mystery. Perhaps a previous owner added the coding using VCDS not realising that it wouldn’t work, and didn’t remove the coding after?
1 - 2 of 2 Posts
