2014 A5 2.0T
Is it mandatory to get adjustable arms when lowering your car on coilovers or you need it when you go really low like slam it? Can one get away with coilovers without adjustable control arms? Thanks
You don't have to get them, but it is advisable if you're going very low, or is just peculiar about factory spec alignment. Normal lowering up to 30mm you'll get away without, granted you will obviously get an increased camber and slightly more wear.
Regards
2014 A5 2.0T
Thanks for the info i just want close the wheel gap and have a stiffer ride..a lil tire wear won't hurt I just ddnt want excessive wear and also I heard so much about quattro and thing u can't do no to mess it up...
