clutch "dragging"
1.3K views 0 replies 1 participant last post by  syramax
#1 ·
hi folks , I have had a quick search through the "clutch " threads and not found what im looking for so here goes. my clutch pedal has gradually needed to be pressed further down into the carpet to get it to disengage and getting first or reverse when cold requires either a pump on the pedal or selecting a gear before starting the engine .gears change ok once the car is moving but the pedal is well down into the carpet making it hard work in traffic . my initial thought is air in the system , ie a leak ,so I would start by checking the fluid level .................................I cant find the bloody reservoir ??? anyone got any ideas ?? its a 2.0l tfsi 58 plate . thanks
