Does the S5 without nav. have this feature?If you have the MMI feature, you will find it in the top-level menu when you press the button marked "car" ...near the bottom of the list.
Hi SFW, it not only depends on the features you have installed but apparently when the car was built. The earlier cars (even with Nav) rely on a dipstick, the later builds with the MMI show the oil status.Does the S5 without nav. have this feature?
'Does the S5 without nav. have this feature?
I don't recall ever seeing any posts from members with US spec cars having this "MMI oil level check" feature. I'm wondering if this perhaps could be yet another feature that varies based upon what country the car is manufactured for.Hi SFW, it not only depends on the features you have installed but apparently when the car was built. The earlier cars (even with Nav) rely on a dipstick, the later builds with the MMI show the oil status.
I am wondering the same TX...we see what mine has tomorrow, but I suspect that my build date is earlier (car was originally here in the US at the end of February '08)...so we may never know.I don't recall ever seeing any posts from members with US spec cars having this "MMI oil level check" feature. I'm wondering if this perhaps could be yet another feature that varies based upon what country the car is manufactured for.
Anyone from the US have this feature?
As TXcarguy says, if you open the bonnet then when you next select the ignition on the oil level automatically shows on the MMI if you've got this function.Thanks for he answer.
This is a really good feature ... a much more easy way to check the oil level.
My VIN is way beyond that (but yet I have a dipstick). More and more, I'm starting to conclude that this feature is available only on non-US spec cars.It is depended on oil sensor.
Cut off VIN is 8T-8-22500. It was in the middle of Dezember 2007.
My VIN is much earlier than that cutoff VIN too, but I also have a dip stick (and no MMI display).It is depended on oil sensor.
My car was made in November ... s***
I agree. I got my car 4/08 (ordered 12/07) and mine has a dipstick as well. For what it is worth, my last car had a sensor for oil levels rather than a stick, and although it seemed to work well, I was always a tad nervous that I couldn't do that visual check to make sure. Although it is a neat feature, I am happy to be back to the old way.I agree with TX that it may be country dependent. Mine was a late January build and has a dipstick.
+1 On the BMW (eh-hem...other car), there is no dipstick and you can only go by the computer...have had the car for over a year and it is weird not being able to see the oil...I agree. I got my car 4/08 (ordered 12/07) and mine has a dipstick as well. For what it is worth, my last car had a sensor for oil levels rather than a stick, and although it seemed to work well, I was always a tad nervous that I couldn't do that visual check to make sure. Although it is a neat feature, I am happy to be back to the old way.
