1 - 10 of 10 Posts
Hey guys, I removed first spark plug driver side. Looked inside with a Boroscope. Can anyone tell me how to determine if you need a carbon buildup. I attached pictures. Car has 72k just got it. Don't have any of information on previous carbon cleaning. Installed a catch can already to help
177595
177596
177597
Well......dunno but I guess that with 72k miles on a V8 I would do a carbon clean anyway.....
Reactions: S5seko and ApoK
The thing is, you can't really tell by looking through the spark plug hole as the carbon gets built up on the back of the inlet valves.
As Simon says it will probably be ready.
Discussion Starter #4
Yes, I figured out that later. I think the day I will look into the intake side, I better clean it the same time. Thanks.
2008 MY09 Audi S5
Did mine at 112k km on my 09 S5.
177639
Before Walnut Blast clean
177640
After
177641
All done (by my mechanic :) )
Discussion Starter #7
I installed a Catch Can, that gets a little bit of oil each week when I check. That will surely slow the carbon build up.
2008 MY09 Audi S5
Wow that really clean. Walnut get the best results. How much did the mechanic charge for the cleaning. I am in Georgia USA, I need to find a good mechanic who can do it.
I am based in Australia. My mechanic only charged about A$715 (6hrs labour & walnuts). I also had new spark plugs (NGK platinums), fuel injector done as well. I asked about a catch can and he was not a fan due to something about possible pressure issues..
2008 MY09 Audi S5
Also had mag alloy intake manifold corrosion fixed (he has seen this before and knows a guy who does cast alloy welding repairs!), otherwise a new manifold is like A$5-7k here.
177642
177643
He is a good guy for sure mate!!!
1 - 10 of 10 Posts
