141 - 160 of 169 Posts
Discussion Starter · #141 ·
Nice work! What's the trick to getting the front bumper off?
Regards
2x 10mm bolts inside wheel arch liner, jack up & put in full lock.
Remove plastic radiator top cover, few torx screws & some underneath for under tray, 20min job, fit in reverse
Sent from my SM-N950F using Tapatalk
My water pump needs doing too, don't suppose you know if those parts are valid for CCWA too?
Discussion Starter · #144 ·
Got this beauty coming soon, only decent I've seen for a sport non s line pfl, & just swapped out old puddles for l some new from Parkes Dynamic Retrofits
176253
176254
176256
176255
looks great where did you purchase the rear diffuser from? I've been looking for a while had one which was a very poor fit..
Discussion Starter · #147 ·
Was from eBay stamped reiger but think a copy, came from Poland
I never got tired of getting in mine and driving it,I only sold it because I wasn’t prepared to throw more money at it.cost me £4500 I two years but a great car and quick!
You had the clutch and flywheel done?
Discussion Starter · #149 ·
Nope all original still @218k, done waterpump, bottom pully & a wheel bearing in 4 years
Looks good!
As mentioned some diffusers, unless you are paying in the hundreds are ill fitting, so I made my own! :)
Are those tail pipes built in to the diffuser like an RS?
:D they're the exact same tips I put on my 3.0 tdi! (y)
They are very close to the diffuser, have you had any vibration or rubbing of you holes? ;)
Discussion Starter · #154 ·
Had a little when cornering, bunged a rubber exhaust mount between underside & back box stopped it
Discussion Starter · #157 ·
Good handy tip for any / many who want to add bluetooth streaming / DAB / phone calls, without already installed.
Amazon Echo auto, pairs to phones bluetooth not wifi hotspot like dots, & either plugs into 3.5mm aux or Bluetooth if have, I use an ami-3.5mm lead.
Plays all the usual digital radios, all voice controlled like any echo, Spotify, even music on your phone & YouTube etc.
I'm still to fit it permanently, thought inside or under sun glasses holder or under dash above screen so can still see the notifications blue light
Discussion Starter · #159 ·
Few little jobs done, bank of 3 injector seals on one side. 2 were like say went in, back 1 been blowing for a while & made a mess in there.
Had Engine Carbon Clean again for a maintenance clean.
Ordered new brake discs & pads all round, front drill groved vibration getting back & so much dust, rears never been done yet by me.
