121 - 140 of 169 Posts
Discussion Starter · #126 · (Edited)
Got myself another set of segments to refurb to like new, & resell. 2tyres are bald & disposed of 2 are 5mm which buyer can have.
19" 9J et33 5x112 66.5mm
Sent from my SM-N950F using Tapatalk
Discussion Starter · #127 ·
Full brake & clutch fluid change make so much difference, never had one before on previous cars, done at dealers £65 set price Inc video health check, vacum & wash
Discussion Starter · #128 ·
Made a start on Subwoofer upgrade, easy enough to remove trim & shelf just take your time.
Ordered a vibe powerbox micro sub amp, small enough to fit in the amp / satnav rack in boot side compartment & the Vibe slick 10" sub. Amp is 800 w max & sub 1050 w max so should be a vast improvement on factory.
Also going to dynamat the metal of the shelf
Very nice thread with some good mods
Well done mate
Reactions: sbones
Discussion Starter · #130 ·
All finished, sounds awesome but still needs running in, plenty of fine tuning & can still adjust from sound option in mmi.
Being 10" new sub fitted the factory hole ok, just the A5s shelf isn't flat so made a quick mdf baffle board, all sealed & screwed down, can't even tell now trim & speaker covers back on
Very good thread.. Been looking at doing something similar, what about the wiring? Is it straight forward?
Discussion Starter · #132 ·
Couldn't be any easier with this amp, no need for a remote on wire! Phono input has just speaker wire other end, that I joined to sub speaker wire. Battery & earth straight to battery in boot & earth bolt, then sub cable just short run behind trim to sub.
The amp instantly turns on when detects an input.
Because input connected to factory sunwoofer cable can adjust from mmi screen.
Definitely recommend an mdf board as metal parcel shelf in coupe still flexes with a lot of bass
Discussion Starter · #133 ·
Gave her a full da polish with G3, then auto glym polish, best ever looked got rid of all swirls & any scratches
175761
175760
Also some twist fix number plate clips & new short gel fhc plate
175762
Discussion Starter · #137 · (Edited)
Had a new auxiliary belt, waterpump & crank pulley fitted, bearings gone in pump & seen many horror stories where the pulleys rubber have broke away lately, definitely a lot quieter now. While bumper off a little tlc, sprayed everything black again & redid the crash bar black with a discreet Quattro logo.
176079
176080
176081
176082
Nice job, can you post up the part numbers, please - sounds like a sensible move, cheers!
Discussion Starter · #139 ·
3.0tdi capa 2007
U06E 121 018 D water pump
U059 105 251 DJ pulley
UWHT 003 351 shim
UN 910 059 02 pulleybtorx bolts x 8
UN 101 961 05 pump bolts x 7
UN 910 522 01 pump pulley bolts x 3
Nice work! What's the trick to getting the front bumper off?
Regards
