1 - 12 of 12 Posts
Hey gents,
Looking around but can’t see anything. The VCDS threads haven’t been updated in a while.
Curious to know what I can do with my Rosstech on the B9 RS5.
Anyone able to help point me in the direction I need to go?
There’s not much but the car shares the same platform as the Q7 so if you google for it you’ll find a list.
I’ve enabled:
Increased distance for window/opening closing via key
Unlock beep option on MMI
Rear roof lights switch on with front dome light on door opening.
Think that’s it.
You can also enable lane assist if your car doesn’t already have it but it’s permanently on if you don’t have the stalk.
I retrofitted automatic parking and used VCDS to code it but that’s obviously out with the normal scope of just tweaking things.
There is the list of possible VCDS/OBDeleven/ODIS changes for B9:
I just check I have this option, but it doesn't really work...? Is there any additional settings?
I think from production it works only for seat cushions, but the seat doesn't go back.
I haven't test this coding yet, the seat should go back.
Exactly like you wrote. Have option in MMI, but seats are not moving. Need buy buy NEW VCDS cable to activate that.
When you have time, please try if it's working?
BTW: What software do you use, ross-tech VCDS for new platforms or any other?
I need the new VCDS cable too, now I use OBD eleven for this, only disadvatage is it's Android app, I use ODIS too.
Hi C99,
Wondering if you have another version of the VCDS/OBDeleven/ODIS changes for B9 list that you attached?
For some reason there is some missing info on the attached list(but it's listed in the header part). Specifically I'm looking for the missing section "DRL’s on with Turn Signal and Scandinavian DRLs (Tail lights on with DRLs)".
Thanks, Mike
Tailights with DRL:
VCDS
09 - Central Electrics
07 Coding
Byte 02 > Bit 3 change 0->1
or ODIS/OBDeleven:
Long Coding
SL_AT_DRL : not active -> active
DRL on with Turn Signal (not possible for LED Matrix):
ODIS/OBDeleven
Long Coding
drl_at_indication_config
Default Value: full_available,
New Value: dimming_to_sl
Tailights with DRL:
VCDS
07 Coding
or ODIS/OBDeleven:
Long Coding
ODIS/OBDeleven
Long Coding
Thanks! Much appreciated!!
1 - 12 of 12 Posts
