1 - 7 of 7 Posts
Had my 3.0TDi for 3 months and I've just driven home with only the front speakers working properly, rear speakers really faint, have played with the fader option with no result. Any one else had this.
I have had no problems myself, but as a long time musician who has hooked up a lot of sound equipment, it sounds like one of 2 problems. Either the power amp is damaged, or there is a problem with the connections. It would be highly unlikely to have a failure of so many speakers at the same time. I think the power amp is in the trunk behind the driver side panel/door. Check to see if any of the wiring harnesses are obviously disconnected. Beyond that, this is too expensive of a stereo to tinker with (unless that is a specialty of yours) so I would take it to the dealer.
Discussion Starter · #6 ·
Have had a look at the amp only 2 connectors on it, all seems ok.The car has standard glass so no added window tint. Off to the dealer next week. Thanks the pair of you, will keep you informed.
1 - 7 of 7 Posts
