That sounds about right. I briefly had an 08 TT with base Concert and that had Aux in (as does newer A3). You probably have a jack lead kicking around anyway if you are into computers, the standard PC Audio Jack (?3.5m) on either end fits the Aux in socket on the car and iPod. No displays on car (TT) You have to drive the iPOd itself and no chargerI've got a standard 09 model A5 . Has a power supply and 3.5mm Aux In under the centre armrest so I can use the ipod there. Got a lead off ebay for a few quid that works fine.
What country are you located in? Please update your profile to display your location. This will help forum members in determing where the differences exist in the car options from country to country.I've got a standard 09 model A5 . Has a power supply and 3.5mm Aux In under the centre armrest so I can use the ipod there. Got a lead off ebay for a few quid that works fine.
Yes, my information is also that AUX is there in the center armrest with the normal radios, with satnav since model year 2009 this (starting last summer), although cars with Audi Music Interface AMI do/may not have it (although AMI allows you to use an extra-priced AUX cable to connect AUX sources into the AMI itself).Does the a5 have a AUX port like the new A3 models?
...eh... why couldn't someone with factory AMI similarly retrofit the aux?I have the AUX under the armrest. I have the MMI 3G but not the AMI. Så retrofitting the AMI will give me both![]()
