This can happen if the window module loses its adaptation. This might occur for for various reasons, most common being a battery disconnection. In this case, I'm not sure why, since it's only one side. But if that's all it is, it's easy to reset per the instructions in the owner's manual.
Raise the window by holding the switch up until it stops moving (fully closed). Release it, then hold it again for at least 1 second. That serves to tell the window regulator what is fully closed. After doing this, the one-touch should be active.
