Is the radio always on? If you wanted just the navigation map on display and wanted no music in car is the only way to lower the radio?
You don't have to turn it down - you can just press the volume control on the centre console and it will mute the system. If you are using a CD (and I assume it is the same for AMI connected devices) the music playback is paused.
You can achieve the same thing by winding down the volume using the steering wheel controls.
press and hold volume knob. turns audio off.
