Hi guys,
I have an Audi S5 4.2L V8 that isn't far away from being set on fire...
It's developed a misfire that's worse when it's cold, until it gets warm - then after a long drive it is worse again.
Feel it slightly at idle but up until 2.5/3k RPM it's fine, then it starts kicking in worse and triggers the EPC light.
So far, I have changed the following:
8 x new spark plugs
8 x new coil packs
4 x new coil pack connectors (as they were snapped)
It's got slightly better, but still not there!
It's brought up the following codes, after I changed Spark Plugs & Coil Packs when it was still misfiring
P130A - 001 - Cylinder Disabling
P0087 - 008 - Fuel Rail/System Pressure Too Low (this hardly comes up, think it's come up twice in the space of a few months)
P1367 - 004 - Cylinder 5 Ignition Circuit - Open Circuit
P0305 - 001 - Misfire Detected Cylinder 5
P2316 - 001 - Control Circuit for Ignition Coil 6 - Short To Plus
P0306 - 001 - Misfire Detected Cylinder 6
I also had the following codes come up once, which I am guessing is due to the misfire:
P0421 - Warm Up Catalyst Efficiency Below Threshold Bank 1
P0431 - Warm Up Catalyst Efficiency Below Threshold Bank 2
I changed the Coil Pack connectors on 5 & 6 as they were completely knackered and thought that might've been it...
And since, it is still doing the same thing (maybe slight improvement), but now brings up
P0302 - Cylinder 2 Misfire Detected when the EPC light comes up
And has also shown P0087 Fuel Rail/System Pressure Too Low code once again (but not come on since).
Any ideas what this could potentially be? Rocker Cover gasket is leaking slightly, but spark plugs didn't make a difference at all.
8 x new spark plugs
8 x new coil packs
