1 - 15 of 15 Posts
What is going on with my Audi...?
The coolant temp used to be around 90deg and since a month it keeps ~73deg all the time :/ the lower temp is visible on the dashboard.
The outside temp from 0 to -16 and the same result all the time... I had even took the fans' fuse but still the same...
I mean a coolant temperature sensor is very cheap circa £10... Lots of tutorials and videos on how to replace it (quite easy), as 73c is very cool considering the temps usually are around 90c.
Hope it helps!
~Alex
VCDS said G395 sensor - hope it will help! ,
Not going to lie that’s the ac pressure/temp sensor...
Perhaps this link might be of use in trouble shooting, but bear in mind the diagrams are for the 4G model so the Audi A6 2011-2018
It’s worth a read! Otherwise might have to go to the car garage to look into further.
~Alex
Then I wonder you know if you turn your AC on does the fan spool up?
does it the A/C gas need to be emptied and renewed / fill up?
also to consider the relay perhaps ... hmm lots to think about when trouble shooting
otherwise there are quite a lot linked with that fault code.
see if any of the above perhaps?
~Alex
Discussion Starter · #11 · (Edited)
Next will be the coolant temp sensor (ordered!) But where is it?
~Alex
My fan is spining all the time - I had to take out the fuse to kill it :(
I will try to check the plugs as well.
The coolant temp sensor replaced - did not help :(
Checked relays - all looks ok
Checked connecter next to brake fluid reservoir - looks ok
Fan control module and connector left...
Do you have a generic code reader or a VCDS?
Because VCDS or OBDeleven (works only with android) will give you a specific fault codes, rather than you throwing parts at it!
With the specific code you could trouble shoot a lot better to be honest!
also either low AC refrigerant or needing to replace the fan see thread:
~Alex
I do - VCDS.
It says P0481-004
Might’ve found another good one for you to look into by the way!
Does this sound about right??
Very similar situation!
~Alex
1 - 15 of 15 Posts
