1 - 6 of 6 Posts
Anyone have access to A5 part numbers versus diagrams.
Looking to get a new underbody plastic tray for my 1.8T (got a small tree branch caught in it and its cracked.)
The panel im looking for is on the left side of the car and it is the middle one of 3 panels between front & rear wheel. The dealer is looking for hundreds so I have found a damaged A5 but would be safer to buy it knowing part number.
· Premium Member
Can you identify which part you require from the picture in Robb's post. If it is number 4 then it is priced at 38.07 Euros according to ETKA (updated to 714). Item 1 is 4.76 Euros and item 6 is 16.39 Euros.
Are you saying that your dealer wants £££ to supply and fit? :eek: Sounds like he has the wrong part identified or is having a laugh.
Cheers,
Thats exactly what i was looking for. Its part marked 4 on that. Now there are two part numbers for the left side. Do you know anything about model PR-1SJ etc as listed or can you check against chassis number.
Also, is that system available on the net or where did you get it?
· Premium Member
There are 2 parts numbers for the left side item 4. PR-1SJ is something to do with an additional engine guard.
The best bet is to PM me your VIN and I should be able to give you an accurate answer.
It's best not to ask on a public forum :rolleyes: ;)
1 - 6 of 6 Posts
