1 - 11 of 11 Posts
Has anyone here successfully retro fitted the rear sunshade in their A5/S5? I was able to purchase the various bits, and installed per Audi wiring diagrams and instructions. The issue is programing module 46 via VCDS. The rear sunshade motor is wired to the BCM2 part number 8K0-907-064-KM, and the front switch part number 8K2-959-674-JV10 wired to BCM1 part number 8K0-907-063-DH. VCDS gives me "out of range" error message. Any suggestions?
Discussion Starter #2 (Edited)
Audi A5/S5 rear sunshade retro fit sorted!
Thanks to Slobo7x, i have completed the retrofit and programing. If anyone is interested in doing the retrofit, I have complied a list of parts, Remove/replace instructions for the sunblind, and wiring diagrams below.
I bought my parts from www.audiusaparts.com.
If you have to replace the BCM2/CCM module, take it to a dealer to have them swap and remove component protection and code your keys!
2008-2010 need BCM2 module that support highest level (comfort convenience module 8K0 907 064 CS works, AS, DS may also work)
2011-2016 models need BCM2 module that support highest level (comfort convenience module 8K0 907 064 KP works on my 2016 S5, 8K0 907 064 CH works on 2011 A5)
1 8T0 863 411 BK 7U3 Rear package shelf with blind (Blk)
1 8K2 959 673 J V10** Switch (Parking sensors,ESP,Rear Sunshade) US spec left hand drive
or 8K2 959 673 H V10** Switch (ESP, Rear Sunshade) US spec left hand drive
1 8T0 867 287 AV48 Rear upper quarter panel Left (Blk)
1 8T0 867 288 AV48 Rear upper quarter panel Right (Blk)
1 8T0 863 6754 PK Track Cover Left (Blk)
1 8T0 863 6854 PK Track Cover Right (Blk)
1 8T0 864 3064 PK Track Right
1 8T0 864 3054 PK Track Left
2 N91123501 Track bolt Left/Right
**If you are needing switches for right hand drive cars (UK and Asia) use 8K1 959 673 J V10 or 8K1 959 673 H V10
Audi service wires and connectors complete harness.
3 wires from Sunshade motor to BCM2/CCM module T17p pin 1 & 2 and ground
Switch wire in front goes to BCM1/CEM module pin 14
Basic instructions:
Fold down rear seats
Remove c pillar trim
Remove speaker covers carefully and the speakers
Remove parcel shelf
You will need to install the c pillar tracks first
Install new package tray with sunblind
Install new wiring harness
Install C pillar trim
Wire front switch
Use VCDS to activate sunblind in module 46 byte 44
Nice work! Could you take a picture or two? I’m really curious as to how it turned out for you. Obviously I’ve never seen one as they’re not an option in the UK.
Discussion Starter #4 (Edited)
Took some pictures today.
Oh, nice work! Very well done. And, you’ve solved a mystery for me - I finally know what the last button in the row does!
What plug does the switch wire goes to? I understand that you said its pin 17 but theres more than 1 plug on BCM1.
Discussion Starter #7
Switch wire in front goes to BCM1/CEM module pin 14.
There are multiple plugs on BCM1 and saying pin 17 isn't specific enough. I am just trying to not make any corrections or mistake.
Discussion Starter #9
If you look carefully on the attached wiring printout diagram, the switch wire is pin 14 (not pin 17) in the 32 pin connector. There should only be one 32 pin connector. You should also check to make sure you have the correct BCM1 and BCM2 modules.
Thanks for clearing everything up for me. I also had a brain fart and didn't actually see all the PDF files and was just going off of the comments. However, I do have the correct CCM ending with "DG" and I'm guessing BCM1 or hoping but I think I'll be good. I retrofitted lots of things already. I plan on doing a YouTube video soon but I think I have one of the most modded S5 out there.
Hi. I need help. I install electric sun roller to my A5 Coupe. Installation is ok, wire i have problem.
1 PIN roller --- > 1 PIN BCM
2 PIN roller --- > 2 PIN BCM
where in rollo is 3 PIN ? i know connect to ground car. Where is 3 pin in roller ? Thanks.
1 - 11 of 11 Posts
