So I managed to pick up a gloss black interior trim piece for around the screen. I had wrapped mine to see if I liked it and I did, however the one I have the screen must’ve been slightly larger. Has anyone managed to get the inside trims out which goes around the screen and put that into another one?
I’m referring to the Matt black surround. There seems to be a way it’s held in and as if it could come out but don’t want to force anything.
Yes, there's a wide sctreen version of the MMI, so you have to carefully melt out the securing tabs with a soldering iron- it's a really fiddly job to do neatly and then when you glue the replacement back on it's easy to end up with visible glue marks in the corners, but it is do-able..
