Hi all,
New to the forum so hello everyone.
I'm hoping someone can help and possibly give some guidance.
After being disappointed by the dealers and their incompetence I have taken on the following myself.
I have a 2014 A5 quattro Sportback. For a while I had a fault light on the dash. I'd asked Audi numerous times to investigate and the came back with nothing helpful. I gave the the fault code, asked them what it means and where the turbo pressure sensor is, again no help.
I then invested in VCDS as my previous one I had for a previous TT was out of date. After investigating and researching online I found it was the actuator that seemed to be the culprit.
New actuator ordered and fitted. This is where I'm in need of some assistance.
I have fitted the actuator and set the voltage between 3.6-3.9v its actually about 3.6v and change. Then I couldn't seem to run the first adaptation, it starts but the stops and says aborted-safety reasons.
After a few attempts and it getting dark I decided to put the car back together. I gave it a test drive to seem if the fault code would come back.
The next day I plugged in and scanned, no faults, so the initial issue had been sorted. After a couple of days driving (seems to drive fine, no issues) I decided to give adaption another go. Again the same issue when try to do the first adaptation- aborted-safety reasons.
Can anyone shed some light on this and what I maybe doing wrong.
Much appreciated
Sorry about image quality, zooming in helps see the figures.
Much appreciated
