Hi All.
Relatively new to Audi's so haven't come to changing bulbs - until yesterday.
So, my passenger side dipped beam needs changing.
I believe they are standard H7's.
I think it looks like this.
My question is, how do i change the thing?
Does the unit need to be taken off?
Also, rather than the standard yellow light, can i change it to a whiter colour?
Discovered this part was broken this morning on my A5, anyone know what it is? I believe this is the cause of a knocking sound when going over large bumps coming from the rear near side suspension
My wipers are acting strangely, sometimes work fine, other times not at all, then they go from fast to slow and slow to fast.
From what i've read I think I need a new relay, does anyone know where it is located and how much to replace?
cheers
Hi, I’ve had my 2008 A5 3.0 TDI for about a year and a half now, and it’s always had issues with the power steering where when turning a corner, the power steering will cut out. It’s particularly bad when parking; the steering always knocks and power steering often cuts out.
It’s getting worse...
Hi
New to posting on this forum, been here a while and usually find most I'm looking for.
I recently changed my battery (bought through an Audi dealer) and thus found a reason to try my OBDeleven to update the BEM code.
As I discovered I had the pro version i ran a scan of the car and found the...
