1 - 8 of 8 Posts
Hello
I have problem with my audi A5 because power steering suddenly stop working yesterday. Checked on carly and carista.Only one fault with j500 module. Fault 01309. Checked on carly and carista
Need somebody who can check on VCDS (Cheshire-Crewe)
Probably need reflash with odis or change rack...
mhhauto.com
Audi A4 8K Steering Assist Chksum error!
2
mhhauto.com
mhhauto.com
I checked all cables and fuses and connection.
Any ideas?
Lukasz
Hi Lukasz
Lets start simple. Someone recently had this and it was because of a dying battery. As the battery gets low on charge (and struggles to recharge) the low voltage can produce random system failures. See link in forum: Defective steering warning
Failing that, have a search of all the forums (search bar at top of screen). I searched the words defective steering and got these results (it it helps): Search results for query: defective steering
Hopefully not a module gone yet. It could be something simper.
Thank You savs for the answer.
I think it is not the fault of the battery because the error occurred after a longer route and after restarting the car. I checked on the plug that comes into the module and the voltage is 13.7
unfortunately the error does not want to be removed ...
Discussion Starter #4
can anyone know if I change module in rack it will work without coding?
My module
8K0909144B
8K0909144D
new module
8K0909144B
8K0909144P
Could well be a battery problem and this is not dependent on the voltage mate. You need to connect VCDS to understand what is going on.
My battery was fine but a bad alternator regulator caused a lot of electrical problems, sending incorrect voltages to modules which stopped them functioning correctly.
Discussion Starter #7
Hi guys
Full scan vcds but is in polish
If will be some problems with translate I can help
Is only fault about steering
Adress 44
6291727 - Sterownik uszkodzony
B2000 00 [137]
Poniedzia?ek,15,Czerwiec,2020,11:52:18:00009
VCDS -- Emulator VAG/VAS pracuj?cy w ?rodowisku Windows, uruchomiony na Windows 8.1 x64
Wersja VCDS: AKP 19.6.2.1
Wersja danych: 20200101 DS308.0
www.vcds.pl
VIN: WAUZZZ8T7DA016659 Numer rejestracyjny:
Typ podwozia: 8T-AU48 (8R0)
Skanowanie: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8T7DA016659 Przebieg: 177300km
01-Silnik -- Stan: OK 0000
02-Skrzynia biegów -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
04-K?t skr?tu kierow. -- Stan: OK 0000
05-Zezwolenie startu -- Stan: OK 0000
08-Klimatyzacja -- Stan: Usterka 0010
09-Centr.zesp.elektr. -- Stan: Usterka 0010
15-Airbag -- Stan: OK 0000
16-Ko?o kierownicy -- Stan: OK 0000
17-Zest.wska?ników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
42-Elektr.drzwi kier. -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: Usterka 0010
46-Modu? komfortu -- Stan: OK 0000
52-Elektr.drzwi pas. -- Stan: OK 0000
53-Hamulec postojowy -- Stan: OK 0000
56-Radio -- Stan: OK 0000
5F-Elektr.informacji -- Stan: OK 0000
62-Drzwi tylne lewe -- Stan: OK 0000
72-Drzwi tylne prawe -- Stan: OK 0000
Adres 01: Silnik (J623-CJCA) Plik etykiet:. 03L-906-018-CGL.clb
Oznaczenie elementu SW: 03L 906 018 HT HW: 03L 906 018 JL
Komponent: R4 2,0L EDC H25 3110
Weryfikacja: 45H25---
Kodowanie: 0A034012232401080000
Kod serwisu: WSC 06208 000 00000
Zbiór danych ASAM: EV_ECM20TDI01103L906018HT 003006
ROD: EV_ECM20TDI01103L906018HT.rod
VCID: 03053A0B8A151157BB-8056
Nie znaleziono b??dów.
Kody gotowo?ci: 0 0 0 0 1
Adres 02: Skrzynia biegów (J217) Plik etykiet:| 0AW-927-156.clb
Oznaczenie elementu SW: 8K2 927 155 G HW: 0AW 927 156 K
Komponent: 0AW 20TDI RdW H04 0008
Weryfikacja: --H04--- Numer seryjny: 0000000885
Kodowanie: 000002
Kod serwisu: WSC 06325 000 00000
Zbiór danych ASAM: EV_TCMVL381 A02432
ROD: EV_TCMVL381.rod
VCID: 397998E3B8599B87A1-806C
Adres 03: ABS/hamulce (J104) Plik etykiet:. 8K0-907-379-V1.clb
Oznaczenie elementu SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Komponent: ESP8 front H09 0100
Weryfikacja: -------- Numer seryjny: --------------
Kodowanie: 171544
VCID: 000F350793030A4FA6-8054
Adres 05: Zezwolenie startu (J393) Plik etykiet:. 8K0-907-064-05.clb
Oznaczenie elementu SW: 8K0 907 064 GB HW: 8K0 907 064 FB
Komponent: BCM2 2.0 H11 0621
Weryfikacja: 00002001
Kodowanie: 01B44040000000000000
VCID: 76E353DFC1C734FF8C-8022
Podsystem 1 - Oznaczenie elementu SW: 8K0 959 754 H HW: 8K0 959 754 H
Komponent: FBSAUDIB8 IDG H71 0083
Numer seryjny: 0812000120904005
Podsystem 2 - Oznaczenie elementu SW: 8K0 905 852 E HW: 8K0 905 852 E
Komponent: J764 ELV MLB H40 0046
Numer seryjny: 2312000152734003
Adres 08: Klimatyzacja (J255) Plik etykiet: Brak
Oznaczenie elementu SW: 8K2 820 043 AJ HW: 8K2 820 043 AJ
Komponent: KLIMA 3 ZONEN H04 0122
Weryfikacja: D1000000 Numer seryjny: 01100720121410
Kodowanie: 342402E000
VCID: 71E960C3A8A913C759-8024
Znaleziono 1 b??d:
00797 - Czujnik promieniowania s?onecznego (G107)
009 - Przerwa / zwarcie z mas?
Ramka zamro?ona:
Stan b??du: 01101001
Priorytet b??du: 3
Cz?sto?? b??du: 1
Wew.licznik b??dów: 196
Przebieg: 177308 km
Wska?nik czasu: 0
Data: 2020.06.15
Czas: 11:49:12
Ramka zamro?ona:
Temperatura: 28.0*C
Temperatura: 22.0*C
Wyj?cie: 300 W
Wyj?cie: 300 W
Adres 09: Centr.zesp.elektr. (J519) Plik etykiet:. AKP\8K0-907-063.clb
Oznaczenie elementu SW: 8K0 907 063 DD HW: 8K0 907 063 DD
Komponent: BCM1 1.0 H16 0103
Weryfikacja: 04016001 Numer seryjny: 00000445011002
Kodowanie: 290000308134B7C00881080300001F1F431D420827080201000008004000020000000024000000
Kod serwisu: WSC 06325 123 12345
VCID: 74E769D7D7BB26EFB2-8020
Podsystem 1 - Oznaczenie elementu SW: 8T2 955 119 D HW: 8J2 955 119 Plik etykiet: 1KX-955-119.CLB
Komponent: WWS 030712 H13 0080
Numer seryjny: SWF12070030099
Kodowanie: 00FD11
Podsystem 2 - Oznaczenie elementu SW: 8U0 955 559 B HW: 8U0 955 559 B Plik etykiet: 8U0-955-559.CLB
Komponent: G397_RLFS H06 0002
Numer seryjny: 20409354
Kodowanie: 02005D
Podsystem 3 - Oznaczenie elementu SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Komponent: E1 - LDS H03 0031
Numer seryjny: 00000000000407121170
Podsystem 4 - Oznaczenie elementu SW: 4H0 907 658 HW: 4H0 907 658
Komponent: AQ_Hum_Sensor H03 0003
Numer seryjny: 0B58CA36000000000001
Znaleziono 1 b??d:
00471 - Sterownik EGD - elektronicznie regulowanego t?umienia (J250)
004 - Brak sygna?u / brak komunikacji
Ramka zamro?ona:
Stan b??du: 01100100
Priorytet b??du: 6
Cz?sto?? b??du: 1
Przebieg: 177308 km
Wska?nik czasu: 0
Data: 2020.06.15
Czas: 11:49:13
Adres 15: Airbag (J234) Plik etykiet:| 8K0-959-655.clb
Oznaczenie elementu SW: 8K0 959 655 N HW: 8K0 959 655 N
Komponent: AirbagVW-AU10 H45 0610
Numer seryjny: 003KFD949RN.
Kodowanie: 30533938363030303030554A305238543053
Zbiór danych ASAM: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 489FED27F3B3F20F2E-801C
Czujnik zderzenia bocznej poduszki bezp.po stronie kierowcy:
Numer seryjny: 6334MSME6E446025E
Czujnik zderzenia bocznej poduszki bezp.po stronie pasa?era:
Numer seryjny: 6344MSME6F454B7B.
Czujnik zderzenia bocznej poduszki bezp.z ty?u po str.kierowcy:
Numer seryjny: 6352QSME7F180364L
Czujnik zderz.bocznej poduszki bezp.z ty?u po str.przedn.pasa?.:
Numer seryjny: 6362QSME0B1A2464G
Czujnik zderzenia przedniej poduszki bezp.po stronie kierowcy:
Numer seryjny: 63732SME271A365A0
Czujnik zderzenia przedniej poduszki bezp.po str.przed.pasa?era:
Numer seryjny: 63832SME1E164B688
Adres 16: Ko?o kierownicy (J527) Plik etykiet:. 8K0-953-568.clb
Oznaczenie elementu SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Komponent: Lenks.Modul H02 0171
Weryfikacja: 00000000 Numer seryjny: 20120716000631
Kodowanie: 000036
VCID: 4FADC63B1EDD25376F-801A
Komponent: E221 - MFL H03 0003
Adres 17: Zest.wska?ników (J285) Plik etykiet:. AKP\8T0-920-xxx-17.clb
Oznaczenie elementu SW: 8T0 920 983 M HW: 8T0 920 983 M
Komponent: KOMBIINSTR. H35 0553
Weryfikacja: 00000000 Numer seryjny: RAR56367D
Kodowanie: 33AF300002012600010000
VCID: 489FED27FBB3F20F2E-801C
Adres 19: CAN Gateway (J533) Plik etykiet:. AKP\8T0-907-468.clb
Oznaczenie elementu SW: 8R0 907 468 H HW: 8R0 907 468 C
Komponent: GW-BEM 4CAN-M H11 0051
Weryfikacja: 1Y050025 Numer seryjny: 2541Y1270300E3
Kodowanie: 80CF07FF00
VCID: 4487F917C79BD66FC2-8010
Podsystem 1 - Oznaczenie elementu SW: 8T0 915 181 HW: 8T0 915 181
Komponent: J367-BDMHella H03 8041
Numer seryjny: 2654867701
Podsystem 2 - Oznaczenie elementu SW: 8K0 959 663 HW: 8K0 959 663
Komponent: J532_DCDCStab H17 0042
Numer seryjny: 12192000232011200181
Adres 42: Elektr.drzwi kier. (J386) Plik etykiet:. 8K0-959-793.clb
Oznaczenie elementu SW: 8T0 959 793 Q HW: 8T0 959 793 F
Komponent: TSG FA H09 0304
Kodowanie: 011002624001450005
VCID: 57BD3E5B260D6DF7B7-8002
Adres 44: Wsp.kierownicy (J500) Plik etykiet:| 8K0-909-144.clb
Oznaczenie elementu SW: 8K0 909 144 F HW: 8K0 909 144 B
Komponent: RCEPS H37 0507
Weryfikacja: 00001000 Numer seryjny: 0031763487
Kodowanie: 100000000001
Kod serwisu: WSC 06334 000 00000
Zbiór danych ASAM: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X_008.rod
VCID: 3467A9D79F3B66EF72-8060
Znaleziono 1 b??d:
B2000 00 [137] - -
[Nowa funkcja - rozszerzone informacje o kodach b??dów (protokó? UDS) - jest dost?pna wy??cznie przy u?yciu najnowszych interfejsów, oferowanych na VCDS.pl.]
MIL zapalona - Potwierdzony - Testowany od skasowania kodów b??dów
Ramka zamro?ona:
Stan b??du: 00000001
Priorytet b??du: 1
Cz?sto?? b??du: 1
Przebieg: 177163 km
Data: 2020.05.31
Czas: 18:01:51
Write only channel
Adres 46: Modu? komfortu (J393) Plik etykiet:. 8K0-907-064-46.clb
Weryfikacja: 00002001 Numer seryjny: 0179580915
Kodowanie: 013F062220B90000832004368000000F
Podsystem 1 - Oznaczenie elementu: 8K0 951 177
Komponent: DWA-Sensor H02 0040
Podsystem 2 - Oznaczenie elementu: 1K0 951 605 C
Komponent: LIN BACKUP HO H05 1501
Adres 52: Elektr.drzwi pas. (J387) Plik etykiet:. 8K0-959-792.clb
Oznaczenie elementu SW: 8T0 959 792 Q HW: 8T0 959 792 H
Komponent: TSG BF H08 0304
Kodowanie: 011002224401450005
VCID: 56A3335F210754FFAC-8002
Adres 53: Hamulec postojowy (----) Plik etykiet: AKP\8K0-907-801-V2.clb
Oznaczenie elementu SW: 8K0 907 801 L HW: 8K0 907 801 J
Komponent: EPB-4 H01 0003
Weryfikacja: -------- Numer seryjny: 00000001144874
Zbiór danych ASAM: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_AU48.rod
VCID: 387F9DE78353828F5E-806C
Adres 56: Radio (R) Plik etykiet: Przekier.nieudane!
Oznaczenie elementu SW: 4G0 035 056 E HW: 4G0 035 056
Komponent: Radio U STD H60 0093
Weryfikacja: AB001007 Numer seryjny: 230GQ0C2566322
Kodowanie: 010003020100000001
VCID: 23455A8B22D5F1579B-8076
Adres 5F: Elektr.informacji (J794) Plik etykiet:. 4E0-035-6xx-5F.clb
Oznaczenie elementu SW: 8R2 035 670 C HW: 8R2 035 670 C
Komponent: H-BNT-EU H44 0524
Weryfikacja: -------- Numer seryjny: 208GV0C7501571
Kodowanie: 13010104020681ED01808B5E00000403040000000000000000
VCID: 3467A9D7973B66EF72-8060
Podsystem 1 - Oznaczenie elementu: 8R0 060 884 AH
Komponent: EUR 2012 1308
Podsystem 2 - Oznaczenie elementu SW: 8R0 919 604 HW: 8R0 919 604
Komponent: DU7 High H41 0104
Numer seryjny: A130GC0CS209935
Podsystem 3 - Oznaczenie elementu SW: 8T0 919 611 B HW: 8T0 919 611 B
Komponent: E0380 Bedient H02 0020
Numer seryjny: 00000001215025
Podsystem 4 - Oznaczenie elementu: 8R0 060 961 C
Komponent: CD-Database 3638
Adres 62: Drzwi tylne lewe (J388) Plik etykiet:. 8K0-959-795.clb
Oznaczenie elementu SW: 8T0 959 795 Q HW: 8T0 959 795 H
Komponent: TSG HL H07 0304
Kodowanie: 010002224001450005
VCID: 59B9386350197B8781-800C
Adres 72: Drzwi tylne prawe (J389) Plik etykiet:. 8K0-959-794.clb
Komponent: TSG HR H07 0304
Koniec --------------------(Skanowanie trwa?o: 03:25)----------------------
Discussion Starter #8
Hello again
finally I managed to flash the driver in odis e but unfortunately a new error has popped up. Unfortunately, I don't know what it concerns. photo below. should I do something else vcds or odis after flashing?
1 - 8 of 8 Posts
